How to fix the issue occured while opening codewarrior 10.6
2,893件の閲覧回数
chennamdhanushm
5 返答(返信)
2,747件の閲覧回数
chennamdhanushm
Thank you for your concern Jennie Zhang.But I'm getting not only the scalability issue but also i couldn't create the new project file.Hope i get solution for this.
Thanks in advance!
Dhanushma
2,747件の閲覧回数
ZhangJennie
Hi Chennam,
I would suggest you remove your .metadata folder of your workspace, then try create new project again.
You may need backup your .metadata before the removal.
Jennie Zhang
2,747件の閲覧回数
chennamdhanushm
I'm using MPC5643L controller
2,747件の閲覧回数
ZhangJennie
Besides, Please check if this article can help you
Eclipse Editor Scalability | MCU on Eclipse
Jennie Zhang
2,747件の閲覧回数
Carlos_Mendoza
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
