How to enable the nested interrupts in CW10.3?
Embionics
I am using kinetis kl25z controller and CW10.3 IDE for my project.
In events.c file, I have called a function(uart_tx) that sends the data over UART. uart_tx() is getting blocked for uart transmission interrupt.
I guess the problem was due to disabling of nested interrupts. Your information regarding how to enable nested interrupts in CW10.3
for kl25z will be helpful for me
regards,
Durgesh
adriancano
Are you using Processor Expert? Can you please share the structure of the Events.c file?
Thank you!
Adrian
ZhangJennie
hi Ammern,
the nest interrupt is automatically managed by Nested Vector Interrupt Controller.  please see attached doc
Zhang Jun
