How to disable optimization for protecting an unused function
2,749件の閲覧回数
jasoncui
I created a function, and didn't call it in my project, the compiler treated it as unused dead code and removed it by the linker. I hope the optimization doesn't work only for this function, how can I do? The CodeWarrior I used is ver5.9, and the MCU is MC9S12G128.
Any help would be much appreciate!
3 返答(返信)
2,562件の閲覧回数
ZhangJennie
Hi Jason.
add the function name to ENTRIES block in prm file can avoid unused function being optimized. can you please try it? can it work for you?
Jennie Zhang
2,562件の閲覧回数
jasoncui
Hi, Jennie
I works well. Thanks a lot.
2,562件の閲覧回数
ZhangJennie
you are welcome!
Jennie Zhang
