How to connect debugger to a MC9S08DZ60ACLH without erasing it
405 次查看
lslonim
Hi, I'm an experienced Embedded guy but new to CodeWarrior. I am running CodeWarrior for MCU Version 11.1, Build Id:181224 because that is the latest version that supports this chip. My debug probe is the PE Micro Multilink LC.
A customer returned one of our products because it reported an internal error. I need to see what is stored in our parameter area of the processor's flash to figure out what went wrong. Is there a way to connect my debug probe to the MC9S08DZ60ACLH without the IDE trying to erase the chip and load new code into it?
Thanks for any help,
Lloyd Slonim
386 次查看
ZhangJennie
Hi @lslonim
Please set debug type as "attached". It will allow to connect chip without erase Flash.
Hope this helps,
Jun Zhang
4 回复数
300 次查看
lslonim
I was able to turn on the "Attach" button by a different approach, finding the config and clicking "Edit". It works great! I really appreciate your help @ZhangJennie !
Lloyd
331 次查看
lslonim
Thanks for the suggestion @ZhangJennie . I tried but the Attach button is not able to be turned on, see attached screenshot. The debug probe seems to be recognized because when I ask it to debug it tries to connect. I have not plugged it into the board yet because I cannot risk erasing the processor. Is there something else I have to do to enable Attach?
Lloyd
387 次查看
ZhangJennie
Hi @lslonim
Hope this helps,
Jun Zhang
313 次查看
ZhangJennie
Hi @lslonim
For test purpose, please create a NEW project in a NEW workspace, how the "connect" option functions?
If "connect" option still gray out in this new project, please upload this new project here, I will check it directly on my side.
Jun Zhang
