How to Create & Use Library
2,280件の閲覧回数
mayursavaj
Hi Everyone,
I want to create Library and want to use in other project.
My question is like.. How to create Library files and use to other project without sharing my Code?
I am using Code Warrior 10.6
Thanks in advance,
Mayur Savaj
3 返答(返信)
2,083件の閲覧回数
BlackNight
Hi Mayur,
I believe the following article should answer your question: Creating and using Libraries with ARM gcc and Eclipse | MCU on Eclipse
I hope this helps,
Erich
2,083件の閲覧回数
mayursavaj
Hi Erich,
Library is created. But unable to use that library files to Other project. (I am getting "invalid variable"  as error).
I m using CW 10.6
Mayur
2,083件の閲覧回数
BlackNight
Hi Mayur,
I'm not sure if I can follow? Can you post a screenshot?
Erich
