Hello, I have two questions. WATCHDOG - PROJECTS
julianferreyra
First question: Why does not the watchdog work in codewarrior 10 with the debugger even if I put the first three bits of the control register 1 (CS1)  in 1 ?
Secondquestion: Can I open projects from the codewarrior individually? I do not want to open the worspace with all the projects at the same time.
Carlos_Mendoza
Hi Julian,
Could you tell us which MCU and CodeWarrior version are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
