Freescale Internal Error
1,614件の閲覧回数
tsybezoff
hi to all
I have a internal error (java.lang.stackoverflow) when open some source file. Please, Help!!!
タグ(2)
1,444件の閲覧回数
BlackNight
Hi Andy,
could you check the .log inside the .metadata of your workspace? This should give you some ideas what is causing the overflow. I guess the Eclipse Indexer might be the problem, then you could try disabling the indexer (see Fixing the Eclipse Index | MCU on Eclipse  for the settings for the indexer).
Other than that, you could set/increase the stack size, e.g
-Xss1024k (see Java stack overflow error - how to increase the stack size in Eclipse? - Stack Overflow ).
See Improve Eclipse Performance with Increased Heap Size | MCU on Eclipse  how to locate the Eclipse/CodeWarrior .ini file (e.g. in <CW>\eclipse\cwide.ini.
I hope this helps,
Erich
