CW5.1 with USB Multilink Universal Rev D
lsrbigfoot
I am experiencing an issue where I cannot use CWv5.1 IDE with PE Micro's USB Multilink Universal Rev. D BDM pods to debug code. However the IDE will work with the previous Rev. C BDM pod I had. Updating the PE Micro drivers to the latest did not help.
What can I do to fix this issue?
ZhangJennie
On my side I have UMultilink Rev A, B and C but I don't have Rev D.
From my view, if your multilink universal can not work with CW5.1, I may suggest you consider check and update multilink universal firmware.
As multilink universal is P&E product, please contact P&E for it:
P&E Microcomputer Systems: Over 30 years as an Industry leader in Embedded Systems Development Tools...
Jennie Zhang
