File not found at link time
2,641件の閲覧回数
pietrodicastri
Senior Contributor II
Good morning
I want to attach the CMSIS library to the project. I have normally added the path and the library to the project properties.
The .png attached describes what happens. It cannot find -llibarm_cortexM4l_math.a but the library is there.
The picture shows the settings and the error.
Some suggestions???
Thank You
2,521件の閲覧回数
BlackNight
Hi Pietro,
have a look at
Creating and using Libraries with ARM gcc and Eclipse | MCU on Eclipse
The thing is that you shall not specify the lib prefix and the .a extension for GNU tools.
I hope this helps,
Erich
2,521件の閲覧回数
BlackNight
Hi Pietro,
have a look at
I hope this helps,
Erich
