ERROR L1115: Function _startup not found
1,972 次查看
sagardhavali
Hello All,
I am being asked to change the code for a project which as S9S12GA46 MCU. Earlier it was having S9S12GNA16 MCU.
Upon modifying the required changes, I am getting above said error. I am attaching the log file here. I hope someone can point me what is that I am missing.
Thank You,
Sagar
Original Attachment has been moved to: _makelog.log.zip
标记 (2)
1,731 次查看
sagardhavali
Problem Fixed.
Apparently, I was supposed to add custom object list to code warrior generated .prm file.
Thank you all.
1,731 次查看
sagardhavali
An Update:
I was able to localize the problem. Apparently the problem is with .prm files.
If I use previous MCU's .prm file (mc9s12gna.prm) for new MCU, I don't have any issue. But If I use the correct .prm file (i.e, ms9S12GA48.prm) I get error (Function _Startup not found).
Hoping to find the help.
