ERROR :    C5200 : xxx.h file not found
5,214 次查看
azeddinehaida
I'm using CW 6.3 in windows xp and I've tried to compile my HCS08 project but i had this tipe of ERROR for many files.h which i'm sure they were in code folder (when i clicked on compile the files.h are deleted).
Thank you in advance
4,540 次查看
azeddinehaida
thank you very much I solved it unistalling and installing CW.
-The specific xxx.h file was included in the project and specified correctly
4,540 次查看
ZhangJennie
good to know.. Thanks for sharing your solutions here!
4,540 次查看
ZhangJennie
HI,
Normally ERROR : C5200 : xxx.h file not found
Is because:
  • - The specific xxx.h file isn’t included in the project, please perform search in your project folder for this file. Can you search it out?
Or
  • - The path or name of the xxx.h file isn’t specified correct. Please check the path setting of it.
Can you solve your problem with above hint? If not, please upload your project here. I will check problem directly from my side. Thanks.
Jennie Zhang
