Codewarrior6.3
Codewarrior6.3
as5818956
  • Codewarrior IDE 6.3 cannot open,"The IDE failure to start suggests that the IDE COM conponents are not registered properly.Run regservers.bat which is found in the same locaition as the IDE.exe program to register the components"
      cannot open the Codewarrior, have tried to  uninstall and install again,     but it just didn't work
ZhangJennie
HI,
Try to run {CW 6.3 install folder}\bin\regservers.bat. Then restart CW.
If this can't work, please try reinstall CW package.
Jennie Zhang
