Codewarrior eclipse ide v10.6
karunanithiprat
Will the Codewarrior eclipse ide v10.6 support MC9RS08LA8  and PE micro usb multilink interface?
ZhangJennie
yes, Codewarrior eclipse ide v10.6 can  support MC9RS08LA8  and PE micro usb multilink interface.
please use the latest CW10.6.4 from this url:
CodeWarrior for Microcontrollers-Eclipse IDE|Freescale
does this answer your question?
Zhang Jun
ZhangJennie
Zhang Jun
karunanithiprat
i already have a source code developed on codewarrior v6.3. how can i import to codewarrior v10.6?
ZhangJennie
please refer this document for porting a Classic CodeWarrior Project into eclipse Codewarrior
http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN4727.pdf
the document is exampled with CW10.4 but the porting method is the same for porting to CW10.6.4
can this help you?
Zhang Jun
BlackNight
The simplest way is to create a new project in v10.6, and then copy your source files over.
Erich
