Codewarrior cannot open,"The IDE failure to start suggests that the IDE COM conponents are not registered properly.Run regservers.bat which is found in the same locaition as the IDE.exe program to register the components"
2,873件の閲覧回数
violetviolet
cannot open the Codewarrior, have tried to open run the regservers.bat,but it just didn't work
2,723件の閲覧回数
Carlos_Mendoza
Hi Violet,
Could you tell us which MCU, Operating systemand CodeWarrior version are you using?
Thanks in advance for your response!
Carlos Mendoza
Technical Support Engineer
