Codewarrior 10.7 Compile problem
1,930件の閲覧回数
mengqingli
I download a demo from NXP website neamed AN5176SW about MC9S12ZVML32_PWM_BLDC_Sensorless. when I compile the project,occurred a error . See the following description:
mingw32-make: *** No rule to make target `C:/BLDC_workshop/MC9S12ZVML32_PWM_BLDC_Sensorless/Sources/S12ZVM_system/startup_CW/S12zvm.prm', needed by `explicit-dependencies'.  Stop.
I have seen the same problem on the community,the replay is clean the project and then rebuild the project can slove this
problem. I tryed do like this ,but the problem still exists。
who can tell me why ? thank you very much。
3 返答(返信)
1,814件の閲覧回数
ZhangJennie
Hi meng,
Please send me your project download link.
I will check it directly from my side.
Thanks.
Jennie Zhang
1,814件の閲覧回数
mengqingli
Dear Zhang:
The Attached is the demo,which I download from the NXP website 。please check it 。thanks a lot。
[email protected]
1,814件の閲覧回数
ZhangJennie
Hi meng,
I build your project from my side. I didn't see any build error.
Please do clean before build.
see attached.
Jennie Zhang
