CodeWarrior local variable storage location
4,874 次查看
xaing_wang
Fresh Out Contributor
In debug,I find that address of  local variable is not Stack。below the figure :
And the local variable define  in function  as follows:
uint8_t i = 0u , j = 0u;
The Ram and Stack define in mc9s12zvl32.prm as follows :
 RAM           = READ_WRITE  0x001100 TO 0x0013FF;
SHADOW_RAM    = READ_WRITE  0x001000 TO 0x001100;
So,I want to know how to define local variables are stored in the stack?
4,637 次查看
ZhangJennie
Hi Wang.
I just checked your project, but I haven't find stack problem.
As I said before, Stack address is inside the RAM section.
see your map file, we can know stack is allocated from address 0x1100 to 0x11ff.
while variable "i" and "j" are in this range.
Does this answer your questions?
Jennie Zhang
5 回复数
4,637 次查看
ZhangJennie
Hello.
Stack belongs to RAM section. Normally if you define a local variable, it should be automatically allocated in stack.
Can you please send me your demo project thus I can check your memory allocation from my side?
Jennie Zhang
4,636 次查看
xaing_wang
Hello Jennie,
      I don't have your email,so,I uploaded to  Baidu SkyDrive demo project。
      tks。
4,637 次查看
ZhangJennie
Hi Wang.
Jennie Zhang
4,637 次查看
xaing_wang
Thank you Jennie。You are right.
I am mistaken "SHADOW_RAM  = READ_WRITE  0x001000 TO 0x001100;"   for  Stack.
By the way,How do I define stack location?such as in the end of RAM.
4,637 次查看
xaing_wang
http://pan.baidu.com/s/1c2Mjrvq   password:i5a7
