In some of the post I've talked about the many advantages that the combination CodeWarrior-Eclipse can bring up. One of those
was the installation on service Packs in a friendlier way than when it's done with the classical view of CodeWarrior. That is why I introduce today the Installing Service Pack for CodeWarrior Tools Quick Start
This Quick Start, in case you are choosing the hard and equally great way to do your own thing with CodeWarrior, it explains how to install a service pack or an update for your classical version of the software running on the Windows platform.
It shows step by step how to do this manually and correctly, preventing you from having an IDE full of stuff you don't even want to use.
