Code warrier upgarde
2,249 次查看
charudattaingal
Dear Team
I upgrade the code  warier 10.6 it got upgraded successful.
At the start up one pop up came PE debugger Firmware is out of date then I upgrade the PE debugger firmware.
Now PE debugger is not working fine It is getting restart frequently.
Requesting help for the same.
标签 (1)
3 回复数
2,091 次查看
ZhangJennie
hi,
what P&E tool do you work with?
Jennie Zhang
2,091 次查看
charudattaingal
Hi Jennie Zhang
I am using PE Micro Multilink universal Rev c and CodeWarrior Version: 10.6.4 Build Id:150416
Thanks & Regards,
Charudatta
2,091 次查看
ZhangJennie
Hi Charudatta,
please download and update the firmware with latest firmware update utility, up-to-date firmware:
http://www.pemicro.com/downloads/main_downloads_temp/201603080313261325454/multilink_universal_insta...
can this help you?
Jennie Zhang
