Can Position-Independent Data be indexed by register A4 instead of register A5?
1,220 次查看
johnchan
I am using CodeWarrior for Coldfire V7.1. I am compiling software for Position-Independent Data. Is there a way to make the compiler index the position-independent data with register A4 instead of A5?
标签 (1)
1 回复
1,142 次查看
jorge_a_vazquez
Hi John Ka Tak Chan
Not, this is a process made by the compiler and there is not method/option to choose between A1-A6. Sorry for the inconveniences that this may cause.
Jorge Alcala
