Can Freemaster connect to MPC5604
hongjianzhang
Today I tried to connect MPC5604 via PE Multilink in Freemaster, But It couldn't work, as the picture says: the device index & name couldn't display, and When I try Test Connection, it couldn't open BDM port, but I can use the codewarrior simulink the chip normally.
