CW10.6  DISASSEMBLER?!
2,258 次查看
peimansh
HI
I want to disassemble a hex file so...
1.project creation\import MCU executable  file
2.enter project name
3.browse hex file(.hex extension isnt in list ,so I select '*' to view my .hex file! is that correct??)
4.device and board(my mcu is MC68HC08AB16 which isnt in HCS08A FAMILY list! what should I do? however I select on to pass this step)
5.finish
then I select my hex file in code warrior project window then r-click to disassemble but "disassemble" is locked!!
please some one help me! I m newcomer in freescale  and have so many problems
sincerely yours%
1,876 次查看
ZhangJennie
Hello Peiman.
please use decoder.exe to disassemble hex file.
see
http://mcuoneclipse.com/2013/04/01/decoding-s19-files/
Hope this helps.
This answer is for you. if it helps, please click on "Correct Answer" Button. Thanks!
Best Regards.
Jennie
