CW TAP + CW for Power Architecture V8.8 configuration issue
3,699件の閲覧回数
mikhail_paulenk
Hello!
I just received CW TAP HW and installed CW for Power Architecture V8.8 (30 days evaluation). We would like to configure tool to have ability program flash only on the target MPC8270 + 28F128P30T flash chips. Target system is in production long time already and no concerns about communication over JTAG/COP. It works with Wind River and works with Macraigor. We would like to validate  CW TAP/COP + CW Power PC IDE 8.8 Flash Programmer specifically.
I followed instruction from CW TAP Manual and AN4780 to setup communication target configuration & etc. But it does not work.
Here are some details.
-   I'm able to ping device from host. TAP getting IP from DHCP;
-   I'm able to access TAP configuration shell over USB/Serial terminal - netparam details & etc.
-   Added actual host name like FSLXXYYZZ + assigned IP address to the table, but anyway not able to ping by TAP name on network, can ping IP address only.
- Put IP address in configuration window instead of Host Name.  It looks like IDE is trying to communicate to target but failed with message "Connection failure" It's hard to say it's failure about connection between TAP and target or between host and TAP.
I tried diagnostic tool instead of flash programmer, the same issue.
Here are some screen shots.
5 返答(返信)
3,520件の閲覧回数
mikhail_paulenk
This is what I’m getting using Ethernet TAP
CCS:
0000
ccs_open
CCS:
ipaddr = 127.0.0.1
CCS:
port = 41475
CCS:
timeout = 15
CCS:
serverh = 0
CCS:
ccs_open; ccs_error = 0
CCS:
0000
ccs_get_connection_count
CCS:
serverh = 0
CCS:
count = 1
CCS:
ccs_get_connection_count; ccs_error = 0
CCS:
0000
ccs_available_connections
CCS:
serverh = 0
CCS:
count = 1
CCS: : ccs_available_connections; ccs_error = 0
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS: 0000
ccs_set_timeout
CCS:
serverh = 0
CCS:
timeout = 15
CCS:
ccs_set_timeout; ccs_error = 0
CCS:
0000
ccs_get_remote_user
CCS:
serverh = 0
CCS:
cc = 0
CCS:
remote_user_hostname =
CCS:
ccs_get_remote_user; ccs_error = 2
CCS:
Error message:
Network timeout
CCS:
0000
ccs_close
CCS:
serverh = 0
CCS:
ccs_close; ccs_error = 0
When using USB TAP. Also gives an
error check you “Please check you JTAG speed.”
CCS:
0000
ccs_close
CCS:
serverh = 0
CCS:
CCS:
0000
ccs_open
CCS:
ipaddr = 127.0.0.1
CCS:
port = 41475
CCS:
timeout = 10
CCS:
serverh = 0
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
ccs_delete_cc
CCS:
serverh = 0
CCS:
count = 0
CCS:
ccs_delete_cc; ccs_error = 0
CCS:
0000
ccs_config_cc
CCS:
serverh = 0
CCS:
config_string = utap:0
CCS:
ccs_config_cc; ccs_error = 0
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
CCS:
serverh = 0
CCS:
count = 1
CCS:
CCS:
0000
ccs_set_timeout
CCS:
serverh = 0
CCS:
timeout = 10
CCS:
CCS:
0000
ccs_config_server
CCS:
serverh = 0
CCS:
cc = 0
CCS:
server_config = 0
CCS:
value = 1000
CCS:
ccs_config_server; ccs_error = 25
CCS:
Error message:
USB open failure
CCS:
0000
ccs_get_config_chain
CCS:
serverh = 0
CCS:
device_list: (size = 0)
CCS:
ccs_get_config_chain; ccs_error = 25
CCS:
Error message:
USB open failure
CCS:
0000
ccs_close
CCS:
serverh = 0
CCS:
CCS:
0000
ccs_reset_to_debug
CCS:
serverh = 0
CCS:
cc = 0
CCS:
ccs_reset_to_debug; ccs_error = 7
CCS:
Error message:
Invalid handle
CCS:
0000
ccs_reset_to_debug
CCS:
serverh = 0
CCS:
cc = 0
CCS:
CCS:
Error message:
Invalid handle
CCS:
0000
ccs_delete_cc
CCS:
serverh = 0
CCS:
count = 0
CCS:
ccs_delete_cc; ccs_error = 7
CCS:
Error message:
Invalid handle
CCS:
0000
ccs_close
CCS:
serverh = 0
CCS:
3,518件の閲覧回数
yipingwang
Hello Mikhail Paulenkou,
First of all, there is problem with CCS USB driver, in order to use CodeWarrior TAP in CodeWarrior 8.8, users need to apply Patch 8.8.6, please download patch 8.8.6 from CodeWarrior Development Tools for PowerQUICC|NXP , DownLoad Eval->CodeWarrior DS for Power Architecture, Professional Edition (Windows Hosted) WIN Evaluation / Updates.
In addition, in the above procedure, it seems that you didn't specify the initialization file when configuring the flash programmer, I attached a step by step user manual for you, please have reference.
Yiping
3,518件の閲覧回数
mikhail_paulenk
As I mentioned Host Name does not work at all.
I put IP address in the Host Name field. It's truing to communicate but failed.
Any idea, please?
3,518件の閲覧回数
mikhail_paulenk
3,518件の閲覧回数
mikhail_paulenk
