CW 10.6 doesn't work on Windows Vista?
2,852 次查看
georg_brno
I just upgraded CW to version 10.6 and I can't run it. Does it work on Windows Vista?
2,669 次查看
ZhangJennie
hi Jiri,
CW10.6 can work for both 32bit and 64bit vista. here is the CW10.6 required Operating System.
Operating System Microsoft® Windows XP 32-bit and 64-bit (Professional Edition),
Microsoft Windows Vista® 32-bit and 64-bit (Home Premium Edition and Business Edition), or
Microsoft Windows 7 32-bit and 64-bit (Home Premium Edition and Professional Edition)
Microsoft Windows 8 32-bit and 64-bit (Home Premium Edition and Professional Edition)
you can find the same information in attached quick start guide.
this answer is for you. if it helps, please click on the correct answer botton.
ZhangJun
2,670 次查看
ZhangJennie
hi Jiri,
ZhangJun
2,669 次查看
georg_brno
Thank you very much. I had to change -XX:MaxPermSize=256m to 128m. Now CW is running.
