C++ not building on eval license
1,860件の閲覧回数
mikelav
I'm using an eval version of CodeWarrior IDE V5.9, arch ver 7.2.  The C++ code fails to build.  The CPP keywords are unrecognized by the build tools.  Am I missing a plugin or setting somewhere?  Shouldn't I be able to compile C & C++ code?
I'm looking for a screen that tells me the license info.  i.e. Eval copy,... 18 days to go,.... licensed professional copy,...
Where can I find this info?
Thank you
タグ(1)
3 返答(返信)
1,798件の閲覧回数
mikelav
The processor is the ColdFire MCF5227.
This appear to be a license issue.  I moved the code to a licensed machine and the C++ issues appear to be gone.  I installed the Eval version of CodeWarrior last week.  (Should still be in Eval mode.)  So apparently the Eval version can't build C++ code.
I've never found readable license info.   i.e. Eval copy,... 18 days to go,.... licensed professional copy,...
1,798件の閲覧回数
Carlos_Mendoza
Hi Mike,
Thanks for your response, as you can see on the following table, only the professional edition comes with unlimited c++ compiler:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
1,798件の閲覧回数
Carlos_Mendoza
Hi Mike,
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
