68HC908AS/AZ + USB-ML-MON08 + CW for MCU
2,218件の閲覧回数
rw_ae2i
Hello everybody,
We are trying to prepare a development environment for a 68HC908AS/AZ CPU.
New to Freescale, we are wondering what kind of hardware and software we need.
We have selected USB-ML-MON08 as programmer/debugger, and we are wondering if CodeWarrior for MCU would be compatible to compile, load and debug software ?
We have looked at v6.3 and v10.6 and we have questions on both :
   - is v6.3 compatible with Multilink MON08 Rev C ?
   - can v10.6 help program HC08 CPUs (we haven't found them in any list) ?
Thanks in advance
3 返答(返信)
2,072件の閲覧回数
rw_ae2i
Thank you all for your answers
We understand your concern about HC08 not being produced anymore, but this is to change and improve an old application, that is why we go back to old software
2,072件の閲覧回数
ZhangJennie
Hello Regis.
Yes, to work with 68HC908AS/AZ, we need to use USB-ML-MON08 and CW6.3.
CW6.3 is compatible with Multilink MON08 Rev C.
CW10.6 can’t support HC08 device. For 8bit, it support HCS08 only.
this answer is for you. if it helps, please click on "Correct Answer" button. thanks!
Zhang Jun
2,072件の閲覧回数
Rick_Li
Hello Regis Wernet,
regarding your questioin:
YES, CW v6.3 compatible with Multilink MON08 Rev C, but CW v6.3 only works in Windows XP, it does not work in Win 7 or later system.
CW v6.3 can also be used to program HC08 MCU.
NO, CW v10.6 does not support HC08 MCU.
PS: FSL HC08 family is not produced any longer, if you want to develop a new application, then, I would suggest using 32 bits Kinetis serial MCU.
