56F84xx_Program_in_FLEXNVM
This project is an example of using the DSC CodeWarrior linker to place code
in a different area of memory.  In this case, the FlexNVM flash block is used.
The example uses three different methods in the linker command file to force
specific code to a different memory segment, see examples below.  For more
information on the linker syntax, see the manual installed with CodeWarrior
at \CW MCU v10.6.x\MCU\Help\PDF\MCU_DSC_Compiler.pdf
This project was developed for the TWR-56F8400 Tower development board, using
CodeWarrior for Microcontrollers v10.6.6.  The project was created using
Processor Expert, and blinks an LED using the PIT timer interrupt.
The linker command file is located at
\Project_Settings\Linker_Files\FLASH_SDM.cmd.Here are the key changes to the
project:
MEMORY {
        # Added .p_FlexNVM memory segment
        .p_FlexNVM(RWX) : ORIGIN = 0x00068000, LENGTH = 0x00004000
# Added .FlexNVM_Code memory section
.FlexNVM_Code :
  TI1_c.obj (.text) # Place whole source file in this section
  OBJECT (FPE_low_level_init, cpu_c.obj) # Place individual function in this section
  * (FlexNVM_code.text) # Place from section defined in source code, see main.c
} > .p_FlexNVM
and in main.c:
#pragma define_section FlexNVM_code "FlexNVM_code.text"  RX
#pragma section FlexNVM_code begin
void main(void)
  /* Write your code here */
#pragma section FlexNVM_code end
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1122046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E56F84xx_Program_in_FLEXNVM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%80%81DSC%20CodeWarrior%20%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E4%BE%8B%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%88%A5%E3%81%AE%E9%A0%98%E5%9F%9F%E3%81%AB%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FlexNVM%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%203%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%3C%2FP%3E%3CP%3E%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%88%A5%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%82%E3%81%A3%E3%81%A8%E8%A9%B3%E3%81%97%E3%81%8F%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%81%AE%E6%A7%8B%E6%96%87%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81CodeWarrior%20%E3%81%A8%E5%85%B1%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3Eat%20%5CCW%20MCU%20v10.6.x%5CMCU%5CHelp%5CPDF%5CMCU_DSC_Compiler.pdf%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%80%81TWR-56F8400%E3%82%BF%E3%83%AF%E3%83%BC%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8CodeWarrior%20v10.6.6%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%80%81%20%3C%2FP%3E%3CP%3EProcessor%20Expert%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20PIT%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20LED%20%E3%82%92%E7%82%B9%E6%BB%85%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%BB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%5CProject_Settings%5CLinker_Files%5CFLASH_SDM.cmd.%E4%B8%BB%E3%81%AA%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%7B%3C%2FP%3E%3CP%3E%23%20.p_FlexNVM%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3E.p_FlexNVM(RWX)%3A%E5%8E%9F%E7%82%B9%3D0x00068000%E3%80%81%E9%95%B7%E3%81%95%3D0x00004000%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%23%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82FlexNVM_Code%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E.FlexNVM_Code%20%3A%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3ETI1_c.obj%20(.text)%20%23%20%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%85%A8%E4%BD%93%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(FPE_low_level_init%2C%20cpu_c.obj)%23%20%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%80%8B%E3%80%85%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E*%20(FlexNVM_code.text)%23%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E9%85%8D%E7%BD%AE%E3%80%81main.c%20%E3%82%92%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%7D%20%26gt%3B%20.p_FlexNVM%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emain.c%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23pragma%20define_section%20FlexNVM_code%20%22FlexNVM_code.text%22RX%E3%81%AE%3C%2FP%3E%3CP%3E%23pragma%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3FlexNVM_code%E5%A7%8B%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Evoid%20main(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%20%E3%81%93%E3%81%93%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%20*%2F%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%23pragma%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3FlexNVM_code%E7%B5%82%E3%82%8F%E3%82%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1122046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%80%81DSC%20CodeWarrior%20%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E4%BE%8B%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%88%A5%E3%81%AE%E9%A0%98%E5%9F%9F%E3%81%AB%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FlexNVM%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%203%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%3C%2FP%3E%3CP%3E%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%88%A5%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%82%E3%81%A3%E3%81%A8%E8%A9%B3%E3%81%97%E3%81%8F%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%81%AE%E6%A7%8B%E6%96%87%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81CodeWarrior%20%E3%81%A8%E5%85%B1%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3Eat%20%5CCW%20MCU%20v10.6.x%5CMCU%5CHelp%5CPDF%5CMCU_DSC_Compiler.pdf%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%80%81TWR-56F8400%E3%82%BF%E3%83%AF%E3%83%BC%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8CodeWarrior%20v10.6.6%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%80%81%20%3C%2FP%3E%3CP%3EProcessor%20Expert%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20PIT%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20LED%20%E3%82%92%E7%82%B9%E6%BB%85%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%BB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%5CProject_Settings%5CLinker_Files%5CFLASH_SDM.cmd.%E4%B8%BB%E3%81%AA%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%7B%3C%2FP%3E%3CP%3E%23%20.p_FlexNVM%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3E.p_FlexNVM(RWX)%3A%E5%8E%9F%E7%82%B9%3D0x00068000%E3%80%81%E9%95%B7%E3%81%95%3D0x00004000%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%23%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82FlexNVM_Code%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E.FlexNVM_Code%20%3A%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3ETI1_c.obj%20(.text)%20%23%20%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%85%A8%E4%BD%93%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(FPE_low_level_init%2C%20cpu_c.obj)%23%20%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%80%8B%E3%80%85%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E*%20(FlexNVM_code.text)%23%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E9%85%8D%E7%BD%AE%E3%80%81main.c%20%E3%82%92%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%7D%20%26gt%3B%20.p_FlexNVM%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emain.c%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23pragma%20define_section%20FlexNVM_code%20%22FlexNVM_code.text%22RX%E3%81%AE%3C%2FP%3E%3CP%3E%23pragma%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3FlexNVM_code%E5%A7%8B%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Evoid%20main(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%20%E3%81%93%E3%81%93%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%20*%2F%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%23pragma%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3FlexNVM_code%E7%B5%82%E3%82%8F%E3%82%8A%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎05-12-2016 04:40 PM
更新者:
