tdt file generating
tdt file generating
abi01
I have one question about CodeWarrior target info file (in my case TargetDataWindows.tdt).
Is this file generated by CodeWarrior (implicitly by IDE), or is it generated by the compiler?
For example if I'm using compiler from command line or by any other build manager,
how can I generate .tdt file?
Thanks for the answer and best regards
CrasyCat
Specialist III
Hello
   The .tdt file is generated implicitly by the IDE.
    You cannot generate it when you are building from command line.
CrasyCat
