problem on tcl command window
robert_zhang
hi all,
i now use tcl script to debug my project.when i use exit or quitIDE command in command window,
the codewarrior will display a message 'a command window is still run,codewarrior will crash'.if i directly close command window with mouse,it will normal.
who konw what's wrong ?
raohechang
Hi, I am stuck with the same problem. Does anyone have a workaround so that IDE quits without stopping on this message?
robert_zhang
have confirm with FAE, it is a bug of codewarrior,so only wait the next version about it.
