my upgrade CodeWarrior DSC v8.3 (Classic IDE)
1,851 次查看
PitOn
Example
Copy current directory
  c:\Freescale\CW MCU v10.5\MCU\DSP56800x_EABI_Tools\command_line_tools\
to
c:\Program Files (x86)\Freescale\CodeWarrior for DSC56800E v8.3\DSP56800x_EABI_Tools\command_line_tools\
5 回复数
1,516 次查看
TICS_Fiona
When build in IDE, CodeWarrior v8.3 does not run the command line tools under:
1,516 次查看
PitOn
Hi Fiona
How to determine at compile time memory model ? DCS Codewarrior
1,516 次查看
TICS_Fiona
To accesses all data by 24-bit addressing modes:
If you build with command line tool, please use -largedata option.
If you build in CodeWarrior IDE, please open target settings by 'ALT'+'F7', and go to Code Generation -> M56800E Processor panel, enable option Large Data Model
1,516 次查看
PitOn
The question is not  set addressing modes . How to determine the memory model at compile time ?
#if(MEMORY_MODEL)
/*    Large Memory Model defines */
#define LoadRx    move.l
#define StoreRx   move.l
#define TestRx    tst.l
#define PTR_SIZE  2
#else
/*   Small Memory Model defines */
#define LoadRx    moveu.w
#define StoreRx   move.w
#define TestRx    tst.w
#define PTR_SIZE  1
#endif
1,516 次查看
PitOn
Answer himself. Рredefined masros __m56800E_lmm__
#if __m56800E_lmm__
#define portPOINTER_SIZE_TYPE unsigned portLONG
#else
#define portPOINTER_SIZE_TYPE unsigned portSHORT
#endif
