maximum stack consumption
2,971件の閲覧回数
Richly
According to section 1.3.2 of the release notes for CW10.1, "Linker computes maximum stack consumption for applications." Where can I find the results of this calculation?
   Richly
2,312件の閲覧回数
CrasyCat
Specialist III
Hello
Please check the document {Install}\help\PDF\Build_Tools_Utilities.pdf.
You should see a section named "Stack Consumption Computation" in there.
CrasyCat
4 返答(返信)
2,312件の閲覧回数
CrasyCat
Specialist III
Hello
CrasyCat
2,312件の閲覧回数
Richly
Thanks.  I hadn't located that directory. Lots of useful information there that hasn't made it into the Help search facility.
    - Richly
2,312件の閲覧回数
CrasyCat
Specialist III
Hello
This is strange. I did a quick test here.
I opened the Search view and entered Stack Consumption Computation in the Search Expression edit box.
It provided me a pointer to the corresponding location in the Build Tool manual (See attached image)
CrasyCat
2,312件の閲覧回数
Richly
Yep...ask the right question, and you'll get a useful selection of possible answers.  Ask the wrong question, and the answer shows up so far down the list, you'll not find it.  I asked the wrong question...though I don't recall exactly what I entered.  Probably something like 'maximum stack size' or maybe just 'stack'.  Whatever it was, I couldn't find what I needed, so your response was most helpful.  Again, thanks!
