help required for codewarrior 4.2.6.862 MIPS
Narasaiah
I am using CodeWarrior IDE Version 4.2.6.
I invoke metrowerks using command line  CMDIDE.EXE %PROJECTNAME% /t %TARGET_NAME% /b
or using ole in perl script.
$CW = Win32:smileysurprised:LE->new('CodeWarrior.CodeWarriorApp','Quit')
$project = $CW->OpenProject($projecttoopen, true, 0, 0);
When the system is locked metrowerks codewarrior throws Unhanded exception :c0000005  At address:005bc027.
can you give solution to this problem.
Narasaiah.
Narasaiah
Hi All,
When the screen is locked in windows xp, the system call to invoke the metroworks IDE fails with Unhandled exception :c0000005 .
Let me know if you have any solution for this problem.
Narasaiah.
