According to the message you are getting I would assume you have created a project with the Stationery and you did not enable floating point support when creating the project.
I would recommend you to create a new project and to make sure you enable floating point support in the wizard. You should be able to link the application after that.
I hope it helps.
Fiona Kuang
Technical Information & Commercial Support
