dsp56805 flash.cfg
dsp56805 flash.cfg
6,404 次查看
zaur0555
Help me please i need the dsp56805 flash.cfg for program DSP56F805 with Codewarrior USB TAP.
6,319 次查看
xiangjun_rong
If you have source code and project, you can use CodeWarrior for DSP56800E ver8.3 tools and generate the file and download via usbtap device.
If you just have S-Record file, you have to use FlashOverJtag.exe tools and Wiggler with PC with 25 pin printer port.
Hope it can help you
XiangJun Rong
7 回复数
6,345 次查看
zaur0555
How can i download CodeWarrior 8.2.3 ?
6,381 次查看
xiangjun_rong
Pls try to use the file I attached.
Pls try to change the extension name from txt to cfg, because I can not attach the file with cfg as extension name.
XiangJun Rong
6,371 次查看
zaur0555
Hi. I tried but this file doesn't work on 56800E Flash Programmer on CodeWarrior 8.3.
I have .s file and can't programming it to dsp56805 MCU.
6,364 次查看
xiangjun_rong
As you know that the DSP56F805 was launched in Motorola in 2000 year, it uses DSP56800 core instead of DSP56800E core, so the 56800E Flash Programmer does not support DSP56F805.
You have to use flashoverjtag.exe tools to download code via JTAG with Wiggler(parallel command converter) and PC with 25 pin printer port.
If you use USBTAP device, you have to use CodeWarrior for DSP56800E ver8.3 tools, but the CodeWarrior for DSP56800E ver8.3 tools can work on Win XP, it has issue to run on Win 10 OS.
XiangJun Rong
6,355 次查看
zaur0555
Could you explain how can i flash the  .s file into dsp56f805 via usb tap on code warrior 8.3 please.
6,320 次查看
xiangjun_rong
XiangJun Rong
6,300 次查看
zaur0555
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1910030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Edsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%20dsp56805%20flash.cfg%20%E7%94%A8%E4%BA%8E%E4%BD%BF%E7%94%A8%20Codewarrior%20USB%20TAP%20%E7%BC%96%E7%A8%8B%20DSP56F805%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%E5%92%8C%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20CodeWarrior%20for%20DSP56800E%20ver8.3%20%E5%B7%A5%E5%85%B7%E5%B9%B6%E7%94%9F%E6%88%90%E6%96%87%E4%BB%B6%E5%B9%B6%E9%80%9A%E8%BF%87%20usbtap%20%E8%AE%BE%E5%A4%87%E4%B8%8B%E8%BD%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%AA%E6%9C%89%20S-Record%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%88%99%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20FlashOverJtag.exe%20%E5%B7%A5%E5%85%B7%E5%92%8C%20Wiggler%20%E4%BB%A5%E5%8F%8A%E5%B8%A6%E6%9C%89%2025%20%E9%92%88%E6%89%93%E5%8D%B0%E6%9C%BA%E7%AB%AF%E5%8F%A3%E7%9A%84%20PC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%88%B0%E4%BD%A0%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E8%8D%A3%E5%90%91%E4%BF%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%A6%82%E4%BD%95%E4%B8%8B%E8%BD%BD%20CodeWarrior%208.2.3%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%A6%82%E4%BD%95%E9%80%9A%E8%BF%87%20Code%20Warehouse%208.3%20%E4%B8%8A%E7%9A%84%20USB%20Tap%20%E5%B0%86%20.s%20%E6%96%87%E4%BB%B6%E5%88%B7%E5%85%A5%20dsp56f805%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E7%9F%A5%E9%81%93DSP56F805%E6%98%AF%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%E5%9C%A82000%E5%B9%B4%E6%8E%A8%E5%87%BA%E7%9A%84%EF%BC%8C%E5%AE%83%E9%87%87%E7%94%A8DSP56800%E6%A0%B8%E5%BF%83%E8%80%8C%E4%B8%8D%E6%98%AFDSP56800E%E6%A0%B8%E5%BF%83%EF%BC%8C%E6%89%80%E4%BB%A556800E%20Flash%E7%BC%96%E7%A8%8B%E5%99%A8%E4%B8%8D%E6%94%AF%E6%8C%81DSP56F805%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20flashoverjtag.exe%20%E5%B7%A5%E5%85%B7%E9%80%9A%E8%BF%87%E5%B8%A6%E6%9C%89%20Wiggler%EF%BC%88%E5%B9%B6%E8%A1%8C%E5%91%BD%E4%BB%A4%E8%BD%AC%E6%8D%A2%E5%99%A8%EF%BC%89%E7%9A%84%20JTAG%20%E5%92%8C%E5%B8%A6%E6%9C%89%2025%20%E9%92%88%E6%89%93%E5%8D%B0%E6%9C%BA%E7%AB%AF%E5%8F%A3%E7%9A%84%20PC%20%E4%B8%8B%E8%BD%BD%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%20USBTAP%20%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%88%99%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20CodeWarrior%20for%20DSP56800E%20ver8.3%20%E5%B7%A5%E5%85%B7%EF%BC%8C%E4%BD%86%20CodeWarrior%20for%20DSP56800E%20ver8.3%20%E5%B7%A5%E5%85%B7%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Win%20XP%20%E4%B8%8A%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%9C%A8%20Win%2010%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%88%B0%E4%BD%A0%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E8%8D%A3%E5%90%91%E4%BF%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910235%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910235%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E4%BD%86%E6%98%AF%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%E5%9C%A8%20CodeWarrior%208.3%20%E4%B8%8A%E7%9A%84%2056800E%20Flash%20%E7%BC%96%E7%A8%8B%E5%99%A8%E4%B8%8A%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%9C%89.s%E6%96%87%E4%BB%B6%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E5%B0%86%E5%85%B6%E7%BC%96%E7%A8%8B%E5%88%B0%20dsp56805%20MCU%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20dsp56805%20flash.cfg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%88%91%E9%99%84%E5%8A%A0%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%B0%86%E6%89%A9%E5%B1%95%E5%90%8D%E4%BB%8E%20txt%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20cfg%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%97%A0%E6%B3%95%E9%99%84%E5%8A%A0%E4%BB%A5%20cfg%20%E4%BD%9C%E4%B8%BA%E6%89%A9%E5%B1%95%E5%90%8D%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%88%B0%E4%BD%A0%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E8%8D%A3%E5%90%91%E4%BF%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E
