codewarrior and XGATE
lin_karl
Hi, right now I have codewarrior 5.9.0 and I want to use it to activate and use XGATE on S12XET MCU. does one know where I can find any info where I can find the help?
thanks,
Carl
CrasyCat
Specialist III
Hello
  I assume you are using CodeWarrior for HC12S V5.1. Am I right?
   To retrieve that info:
     - Start CodeWarrior
     - Select Help -> About Freescale CodeWarrior
     - Click on "Install Products"
     - CodeWarrior version used is displayed on top in the Installed Products dialog.
  If this is the case, just create a new project for HCS12XET using the wizard and make sure you
  specify you want to create a Multicore project.
  The generated project will include some sample code showing how to run portion of the application on XGATE.
CrasyCat
