File->New->MQX 3.7 Project  -->problems
已解决
跳至解决方案
1,474 次查看
cavebiker
Contributor V
I have the eval copy of CW 10.2 and when I try to do "--> File->New->MQX 3.7 Project" The MQX 3.7 Project Selection is not available.
Does anyone know what my problem is?
Thanks in advance
标签 (1)
1 解答
1,291 次查看
cavebiker
Contributor V
Thanks a bunch Tom, I am on-it.
在原帖中查看解决方案
2 回复数
1,291 次查看
J2MEJediMaster
Specialist I
Have you installed MQX yet? If not, I'd strongly recommend that you install MQX 3.8.1 instead. No matter what version you have installed, the MQX choice does not show up automatically in CodeWarrior until you do some preparation. The information for doing this can be found in the Acrobat document FSL_MQX_in_CW_x.pdf. Search for that file and read the directions first, then follow them carefully.
---Tom
1,292 次查看
cavebiker
Contributor V
