Where's my Target Settings panels?
2,100 次查看
DouglasHolubTX
I'm using an ancient version of Code Warrior IDE, version 4.2.6. I have three projects which are very similar. But one of them won't display the Target Settings Panels when I select "Edit" then "Settings". It only displays something called "Access Paths".  What's going on?
标记 (1)
976 次查看
trytohelp
I think the project is corrupted.
Difficult to give you hint to fix the problem.
The better solution will be to create a new project via the File | New menu and to plug all your application files in this new project.
Else if you think you use the same config for projects, you can duplicate one of your other project and add your application files.
Hope this will help you.
Pascal
