Where is the stack size setting in eclipse ?
1,410 次查看
SecondTechCo
 i have found it in project.lcf but not in the eclipse IDE.   I have read one other post which says it is in the build settings CPU but I dont see it there.
1,168 次查看
CrasyCat
Specialist III
Hello
   I assume you are talking about the size of the stack used to run the application. Am I right?
  This is done differently according to the processor you are targeting.
  - Which CPU are you targeting (HC08, HC12, Coldfire, ..)
  - Are you using CodeWarrior v10.x (Eclipse based) or an earlier release of CodeWarrior?
CrasyCat
1,168 次查看
SecondTechCo
I figured out where it was. Eclipse 10.2.  Thanks
