Using Watchpoint to monitor memory
2,681件の閲覧回数
KirbyCurley
How does one set up a watchpoint to monitor if a specific value is being written to a location in memory?
For example:
Break if 0xA5 is being written to the byte address location 0xC0000?
I know how to setup a watchpoint for the address location, but don't know how to use the condition expression to break if 0xA5 is being written.  Using a c expression in this case doesn't make sense as it's a general location in memory.
2 返答(返信)
828件の閲覧回数
CompilerGuru
You forgot to mention which core and which version of CW you are using.
Does something like
*(unsigned char*)0xC0000 == 0xA5
as expression not work for you?
828件の閲覧回数
KirbyCurley
Thanks Daniel.  That did it.
