Using Lauterbach in CodeWarrior
yoavbaryoseph
I am evaluating CodeWarrior 10.5.
I do not have the CodeWarrior TAP, but having Lauterbach instead.
How exactly should I configure the IDE so I can perform debugging of the SW (through the IDE and not through Trace32)?
Yoav
yipingwang
Hello Yoav Bar Yospeh,
CodeWarrior for PA 10.5.1 doesn't support Lauterbash, you have you have to use CodeWarrior TAP in CodeWarrior IDE.
YIping
