Regarding Profiling in MPC8313E RDB
2,757 次查看
mathewsmphilip
Dear All,
I am using code warrior IDE version 5.9.0 (Evaluation version) for MPC 8313E RDB. When i used the example code for profiling (Freescale\CodeWarrior PA V8.8\(CodeWarrior_Examples)\PowerPC_EABI\SimpleProfiler),I am getting the profile time,average,maximum etc as Zeros.
Can you please give me the reasons for this.
These are the steps we followed
We linked the profiler library Profiler.Dwarf2.BE.UC.a .
DWARF settimg :  DWARF 2.x
Byte Ordering : Big endian.
The readme says this example is customized for MPC8555 CDS board.
Whether we can use the same example for MPC8313E RDB??
Please help us in this regard as this info is very critical to our project.
Thanks in advance
Mathews
5 回复数
2,647 次查看
trytohelp
Hi Mathews,
Do you have contacted the Support team too ?
it seems you've already contacted the Support team via CRM system.
the problem has been logged under the 1-1065893211.
My colleague is investigating the problem and will provide you feedback via SR issue.
Pascal
2,647 次查看
mathewsmphilip
Dear Pascal,
I had put the same in the community as a question, Since i didnt get any answer,i put a service request.
Please respond as this already affected my relaese.
Hoping for a fast reply.
Mathews
2,647 次查看
trytohelp
Hi Mathews,
Following the info I found under the SR, my colleague is working on your problem.
He sent you an email early this morning.
Pascal
2,647 次查看
mathewsmphilip
Dear Pascal,
  Got the message this morning.
  waiting for the answer from the factory.
Thanks a lot for the support
Mathews
2,647 次查看
trytohelp
Hi Mathews,
I need to check it and probably need to contact colleagues.
Keep you informed.
Pascal
