Reformating code
Reformating code
1,327 次查看
roadrunner75
I am running CodeWarrior 10. I just imported a bunch of files with the coding style different from what the coding standard is. I wanted to know if there is a way to get CodeWarrior to fix the coding style based on the properties that are setup.
1,186 次查看
roadrunner75
I figured it out.  Just highlight the code you want to change and press CTRL + Shift + F
