Range check error
Range check error
1,976 次查看
Hgida
I am using the MC56F8367 evaluation board. I enabled Processor Expert and when I try to add the 56F8367 CPU bean, I get an error saying "Range check error".
Does anyone know how I fix this problem?
Thanks.
Hardeep
标记 (1)
959 次查看
ProcessorExpert
Senior Contributor III
Could you please write more details on which CodeWarrior version do you use and how did you created the project and added Processor Expert ?
I haven't reproduced the problem, I created the project using Processor Expert Stationery in CW 8.3.
Petr Hradsky
Processor Expert Support Team
