Over whelmed K70 Programming
1,124件の閲覧回数
4boysdad
I won't be doing the programming but the K70 looks very complex. How hard or easy is it to program? Does the CodeWarrior IDE develope the code in C and how is the executable loaded into the K70? Is there a POD?
4BoysDad
p.s. It's obvious but I'm new to microcontrollers.
991件の閲覧回数
crezyoz
Start with the K70 Tower system to get familiar with the development tools. I am only in my third week of the K70 and Codewarrior. It is indeed complex and a painful learning curve. So far anyway. But I always get over those curves.
With the Tower system you will get a P&E downloader/debugger system.
You can code in C/C++ or assembly,  depending on which Codewarrior tool you buy.
