No uninstall for Codewarrior LE v4.0
3,997 次查看
cmspaz
I can't uninstall codewarrior. There is no uninstall app in the codewarrior folder or the start menu group, the Add/Remove Programs window locks whenever I try to do it from there (probably becuase there's no unistall app for it to use), and the install app on the cd doesn't have an uninstall option, as most nowadays do.
I'm at wits end as to what to do, since I really don't want to just go in and delete everything manually. Too many fragments of the program would get left on the drive that way.
Any ideas as to what I can do?
I'm running XP Pro SP2, if that helps any.
2,217 次查看
CrasyCat
Specialist III
Hello
  Which processor are you targeting (PowerPC, Coldfire, HC12, ...)?
CrasyCat
2,217 次查看
cmspaz
I'm not sure. How would I go about figuring this out?
2,217 次查看
CrasyCat
Specialist III
Hello
Is there a file called Welcome*.txt in your root installation directory?
You should see your target there...
CrasyCat
