Mis Aligned Long Word Access Interrupt gets generated.
1,969 次查看
Kanthi
Hello Support Team,
      For my application using MC56F8356, when i execute my code using "CodeWarrior USB TAP" on to the board, the following interrupt gets generated:
Misaligned Long Word Access(Interrupt Number: 5).
I am using following libraries in my application:  MCLIB_5680xx.lib, GFLIB_5680xx.lib and Runtime 56800E libraries in my application.
My application also uses floating point variables also.
I would like to resolve the problem so that this interrupt does not get generated. Please help in solving this issue.
Thank you,
Kanthi Uppala
标记 (1)
805 次查看
J2MEJediMaster
Specialist I
Does interrupt 5 happen to deal with a interrupt handler you wrote, or has this error just appeared out of nowhere? If it is a handler you wrote, you'll need to post the code, otherwise all we can do is guess as to what might be going wrong.
---Tom
