Linux Host [Fedora 3] CW license upgrade problam : (
AshishAgarwal
Sorry to interrupt you all for this silly:smileymad: question.
 i am currently working on Kernel 2.6.9-1, FC3. CW 5.9.0 (Linux host). :smileysurprised:
my  First installed license file was like below.:manhappy:
 ####### IDE #######
FEATURE Linux_CWIDE_Limited metrowks 5.5 permanent uncounted AB1FAA998915 HOSTID=ANY
# ( 821): CW Development Studio for Power Architecture, Linux Platform Edition, v.8.8 (Linux host)
FEATURE Linux_PLUGINS_COMMON_ELINUX metrowks 2.0 05-apr-2009 \
    uncounted DDE56C6EB2FB VENDOR_STRING="Common Embedded Linux \
    Plugins (Linux)" HOSTID=ANY START=09-Mar-2009
FEATURE Linux_PLUGINS_PPC_KDBG metrowks 2.0 05-apr-2009 uncounted \
    21713DF4F15F VENDOR_STRING="PPC KDBG Plugins (Linux)" \
FEATURE Linux_PLUGINS_PPC_LNX metrowks 2.0 05-apr-2009 uncounted \
    F8922E108CB5 VENDOR_STRING="PPC LNX Plugins (Linux)" \
FEATURE Linux_PLUGINS_PPCCPU_COMM metrowks 2.0 05-apr-2009 uncounted \
    8F8AC3CFD9B5 VENDOR_STRING="PPC COMM CPU Plugins (Linux)" \
FEATURE Linux_PLUGINS_PPCCPU_HOST metrowks 2.0 05-apr-2009 uncounted \
    6F2D0513CC59 VENDOR_STRING="PPC HOST CPU Plugins (Linux)" \
FEATURE Linux_PLUGINS_PPCCPU_PQ3 metrowks 2.0 05-apr-2009 uncounted \
    39E61BE4E8FF VENDOR_STRING="PPC PQ3 CPU Plugins (Linux)" \
FEATURE Linux_CWIDE_Unlimited metrowks 5.5 05-apr-2009 uncounted \
    5D5DD1965D3A VENDOR_STRING="CodeWarrior IDE (Linux)" \
FEATURE Linux_CFP_PPC metrowks 8.0 05-apr-2009 uncounted 9D69D983A1FC \
    VENDOR_STRING="PPC Flash Programming (Linux)" \
FEATURE LINUX_PLUGINS_COMP_PPC metrowks 8.0 05-apr-2009 uncounted \
    6E8429B629AF VENDOR_STRING="PPC build tools (Linux)" \
FEATURE Linux_PLUGINS_DBG_PPC metrowks 8.0 05-apr-2009 uncounted \
    752E6DD278E4 VENDOR_STRING="PPC Debugger Plugins (Linux)" \
FEATURE Linux_PLUGINS_PPC metrowks 8.0 05-apr-2009 uncounted \
    048BB670CC63 VENDOR_STRING="PPC Plugins (Linux)" \
FEATURE Linux_Plugins_Link_PPC metrowks 8.0 05-apr-2009 uncounted \
    4B79017D3307 VENDOR_STRING="PPC linker" \
FEATURE Linux_PLUGINS_PPCCPU_MGT metrowks 2.0 05-apr-2009 uncounted \
    D28D88D2105C VENDOR_STRING="PPC MGT CPU Plugins (Linux)" \
Then  i update my license from freescale that gives me file as below. :manvery-happy:
# If this is a floating license, replace  with your
# license server host IP address, or your license server host name
INCREMENT Linux_PLUGINS_DBG_PPC metrowks 8.000 6-may-2009 uncounted \
        83A5A5F334FA VENDOR_STRING="PPC Debugger Plugins (Linux)" \
        HOSTID=000bdbdabed8 ISSUER="Freescale Semiconductor" \
        ISSUED=6-apr-2009 NOTICE=0000 \
        SN=FSL-17bd-6a11-2005-8c83-af74-26 START=6-apr-2009 TS_OK
INCREMENT Linux_PLUGINS_PPCCPU_PQ3 metrowks 2.000 6-may-2009 \
        uncounted 6802CBFECE42 VENDOR_STRING="PPC PQ3 CPU Plugins \
        (Linux)" HOSTID=000bdbdabed8 ISSUER="Freescale Semiconductor" \
INCREMENT Linux_CWIDE_Unlimited metrowks 5.500 6-may-2009 uncounted \
        D3C3A693BC6A VENDOR_STRING="CodeWarrior IDE (Linux)" \
INCREMENT Linux_PLUGINS_PPCCPU_COMM metrowks 2.000 6-may-2009 \
        uncounted B3917C8C8095 VENDOR_STRING="PPC COMM CPU Plugins \
INCREMENT Linux_PLUGINS_PPCCPU_HOST metrowks 2.000 6-may-2009 \
        uncounted E40538E9B040 VENDOR_STRING="PPC HOST CPU Plugins \
INCREMENT Linux_PLUGINS_COMMON_ELINUX metrowks 2.000 6-may-2009 \
        uncounted 3017C42D3527 VENDOR_STRING="Common Embedded Linux \
        Plugins (Linux)" HOSTID=000bdbdabed8 ISSUER="Freescale \
        Semiconductor" ISSUED=6-apr-2009 NOTICE=0000 \
INCREMENT Linux_PLUGINS_PPC_LNX metrowks 2.000 6-may-2009 uncounted \
        4FA0BB878059 VENDOR_STRING="PPC LNX Plugins (Linux)" \
INCREMENT Linux_CWIDE_Limited metrowks 5.500 6-may-2009 uncounted \
        D4FF813B6466 HOSTID=000bdbdabed8 ISSUER="Freescale \
I tried all the combinationfrom the above two files like
1. Replaced the previous file with new one
2. Join both of them straightly
3. Join the new one and adding my host M/c id to all the entries abovepresent as
   HOSTID=ANY => HOSTID=000bdbdabed8
4. Bla bla .. dates tampering. :robottongue:
5. Fedora host date tampering worked [but not recommneded one Obviously :smileywink: ].
so the neck or point i am missing here ...  :smileytongue:
first_install_license.txt
update_license.txt
Message Edited by t.dowe on 2009-09-04 03:16 PM
AshishAgarwal
Freescale support answer for this querry was :
" In reply to your Service Request SR 1-557240821:
The licenses you sent me are both temporary licenses. It looks like you
have an evaluation version of the tools. When time expires, the tools
stop working. You cannot combine, modify, or extend the license.
If you have purchased the tools, you should have a registration number.
In that case, I can help you. Otherwise, you need to purchase the proper
tools. For information about what products and what features are in the
various CodeWarrior Suites, see:
http://www.freescale.com/weba...
J2MEJediMaster
Specialist I
You need to submit a service request on this problem. Click here to do that, then select technical request from the Category pop-up menu, and license issues from the Topic pop-up menu.
---Tom
AshishAgarwal
