Linker file changes not sticking
763 次查看
barbercolman
Using CW10.1 and MQX I have changed the intflash.lcf file and recompiled. After exiting CW and reentering the changes to the linker file have not stuck. This has happened twice. I think this a CW not a MQX issue. Any idea what is happening.
546 次查看
CarlFST60L
Senior Contributor II
I have made my own copy of the linker in the project directory and changed the project to use that Linker and never had a problem, maybe try that.
Copy the intial file, move it to you project directory, then, I put all mine in a folder called LCF, go to project properties and change the following
C/C++ Build > Settings > Tool Settings > (Cold Fiire Linker) > Linker Command File (.lcf)
change this to
${ProjDirPath}\LCF\MyLinkFile.lcf
 Obviously make this match your setup
