Linker does not compress gaps between VLE functions like Reference Manual say
AndyMax
The "CodeWarrior Development Studio for
Power Architecture® Processors Build Tools Reference " says:
-func_align
     Specifies alignment of functions in executable code.
      Syntax
     -func_align 4 | 8 | 16 | 32 | 64 | 128
      Remarks
             The default alignment is 4. However, at an optimization level 4, the alignment changes to 16. If you are using -func_align 4 (or none) and if you are compiling for VLE, then the linker will compress gaps between VLE functions:
 • if those functions are not called by a Classic PPC function
 • the function has an alignment greater than 4.
       NOTE    Compression of the gaps will only happen on files compiled by the CodeWarrior compiler.
Questions:
1. Isn't there a contradiction here or how should this be understood?
"If you are using -func_align 4 (or none) and if you are compiling for VLE, then the linker will compress gaps between VLE functions:"
" • the function has an alignment greater than 4."
2. What is "Classic PPC function" ?
3. Why I still have gaps "00 00" between functions: I compile VLE code and "Function alignment"(Code Generation->EPPC Processor) in Codewarrior project settings is set to "4 Byte" (check attachments)?
AndyMax
FORCEFILES { "module.o" }
For some reason it gives the linker the right to forget about his promises. If you have same issue just remove your module name from it.
AndyMax
AndyMax
UPD1: I created blank project and fill it with example functions, and this project no generate gaps between functions. I'm keeping play with this
AndyMax
... attachments ...
%3CLINGO-SUB%20id%3D%22lingo-sub-2163980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3EThe%20%22CodeWarrior%20Development%20Studio%20for%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EPower%20Architecture%C2%AE%20Processors%20Build%20Tools%20Reference%20%22%20says%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3E-func_align%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSpecifies%20alignment%20of%20functions%20in%20executable%20code.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Syntax%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B-func_align%204%20%7C%208%20%7C%2016%20%7C%2032%20%7C%2064%20%7C%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Remarks%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BThe%20default%20alignment%20is%204.%20However%2C%20at%20an%20optimization%20level%204%2C%20the%20alignment%20changes%20to%2016.%20If%20you%20are%20using%20-func_align%204%20(or%20none)%20and%20if%20you%20are%20compiling%20for%20VLE%2C%20then%20the%20linker%20will%20compress%20gaps%20between%20VLE%20functions%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%E2%80%A2%20if%20those%20functions%20are%20not%20called%20by%20a%20Classic%20PPC%20function%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%E2%80%A2%20the%20function%20has%20an%20alignment%20greater%20than%204.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CSTRONG%3ENOTE%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3ECompression%20of%20the%20gaps%20will%20only%20happen%20on%20files%20compiled%20by%20the%20CodeWarrior%20compiler.%3CBR%20%2F%3E%3CBR%20%2F%3E------------------------%3CBR%20%2F%3E%3CBR%20%2F%3EQuestions%3A%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20Isn't%20there%20a%20contradiction%20here%20or%20how%20should%20this%20be%20understood%3F%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%22If%20you%20are%20using%20-func_align%204%20(or%20none)%20and%20if%20you%20are%20compiling%20for%20VLE%2C%20then%20the%20linker%20will%20compress%20gaps%20between%20VLE%20functions%3A%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%22%20%E2%80%A2%20the%20function%20has%20an%20alignment%20greater%20than%204.%22%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E2.%20What%20is%20%22Classic%20PPC%20function%22%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3E3.%26nbsp%3BWhy%20I%20still%20have%20gaps%20%2200%2000%22%20between%20functions%3A%20I%20compile%20VLE%20code%20and%20%22Function%26nbsp%3Balignment%22(Code%20Generation-%26gt%3BEPPC%20Processor)%20in%20Codewarrior%20project%20settings%20is%20set%20to%20%224%20Byte%22%20(check%20attachments)%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EFORCEFILES%20%7B%20%22module.o%22%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EFor%20some%20reason%20it%20gives%20the%20linker%20the%20right%20to%20forget%20about%20his%20promises.%20If%20you%20have%20same%20issue%20just%20remove%20your%20module%20name%20from%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUPD1%3A%20I%20created%20blank%20project%20and%20fill%20it%20with%20example%20functions%2C%20and%20this%20project%20no%20generate%20gaps%20between%20functions.%20I'm%20keeping%20play%20with%20this%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E...%20attachments%20...%3C%2FP%3E%3C%2FLINGO-BODY%3E
