CodeWarrior® Development Studio for MPC55xx/MPC56xx (Classic IDE) v2.10 is supported in windows 10?
27,871 次查看
sukruthrameshba
I was using CW v2.10 in windows 7. But when i am trying to install setup file in windows 10, It is not working.Error scrrenshot is as shown.
13 回复数
14,438 次查看
AndyMax
I use MacBook Air M1 (OS: Sonoma 14.7.5 (23H527)) with Wine v10.6 to running CodeWarrior 2.10 for coding. It works super fast. Of course debugging is impossible because luck of PEMicro Apple silicon drivers/support. But on this step I don't need it.
27,683 次查看
sukruthrameshba
Hi Jun,
Unfortunately we don't have an option to use windows 7 in our organization.
Do you suggest any alternatives to use CW2.1 for windows 10 ?
Sukruth
27,683 次查看
ZhangJennie
Sukruth
Please use this eclipse version, which can support MPC56xx on win10
CodeWarrior® for Microcontrollers-Eclipse IDE 11.1 | NXP
Jun Zhang
27,669 次查看
sukruthrameshba
Hi Jun,
Are Qorivva® 56xx and POWERPC 5668G both are same?
Because in this tool, I didn’t find an option to select the target from POWERPC.
Sukruth
27,669 次查看
ZhangJennie
yes, when you create a new project with CodeWarrior11, you will see MPC5668G here
27,668 次查看
sukruthrameshba
Installed and trying to import our old project file . Getting the below error.
Is it possible to port project created in CW2.1 to this version?
27,664 次查看
stanish
Hi Sukruth,
Unfortunately project importer does not support MPC5xxx projects (it is dedicated to DSCs only) in CodeWarrior for MCUs 10.x
Anyway, there are essentially two options:
1) stay with CodeWarrior for MPC55xx/56xx v2.10
Althought Windows 10 is officially not supported I've verified it is possible to use it with Windows 10 64bit
(IDE + build tools + debugger)
I'd suggest you to try:
* to run the installer as an administrator.
* enter installation path outside of "Program Files" folder (use e.g. "C:\NXP\CW for MPC55xx and MPC56xx 2.10")
* run the installer with compatibility mode set to Windows 7 if the suggestions above do not work.
* If you install it correctly please download the latest Pemicro Drivers (PEmicro | Experts in Embedded tools for Flash Programming and Development )
2) migrate your project into CodeWarrior for MCUs v11.0
You will have to create a new project, add your source files and cofigure the project manually.
See attached document AN4094 to migrate the build tools settings - CW v2.10 vs. CodeWarrior for MCUs (Eclipse)
The advantage of option #2 is you will get the latest compiler version with many issues addressed.
If you experience any issues while migrating project we can assist you (in such a case please submit a support ticket for a private support channel: How to submit a new question for NXP Support
Hope it helps.
Stan
25,422 次查看
liyue1
I can't use cw 2.10 in Windows 10, and the debug window keeps popping up an undetected disconnected/connected USB cable. I used it https://www.pemicro.com/faqs/faq_view.cfm?ID=29 The method of webpage cannot solve the problem. In Firmware update, the firmware can be recognized and upgraded normally, and the latest version of the driver has been installed. The driver can also be found in Device Manager. I just can't debug.
27,658 次查看
sukruthrameshba
Hi Stan,
Thank you for your response.
I followed the steps mentioned in option 1. But it is not working for me.
I also tried option 2. However, getting many errors in the code warrior IDE. (compiler errors)
Any document describing the steps to migrate from old project in CW v2.1 to new project in CW v11.1 ?
Is there any sample project for MPC5668G with CW v11.1 ?
Sukruth
27,658 次查看
ZhangJennie
There are Qorivva sample under CW install:
C:\Freescale\CW MCU v11.0\MCU\CodeWarrior_Examples\Qorivva_Examples
If you need more assistance, please submit a ticket as Stan suggested.
27,659 次查看
sukruthrameshba
Hi Jun,
Thank you for your reply.
I am using MPC5668g (POWERPC controller).
Please suggest me the suitable CW version for this target.
Sukruth
27,660 次查看
ZhangJennie
Sukruth
I checked MPC5668g. Unfortunately, for this chip, we only have CW2.1. no other newer version.
Please use CW2.1 on our recommended windows platform.
Sorry for the inconvenience.
Jun Zhang
27,659 次查看
ZhangJennie
CodeWarrior® Development Studio for MPC55xx/MPC56xx (Classic IDE) v2.10 can support below windows platform.
Microsoft® Windows® XP
Windows Vista™, 32-bit or 64-bit edition
Windows 7, 32-bit or 64-bit edition
CW2.1 was released before win10 launching time, so win10 is not on CW2.1 supporting list.
What's your chip part number? I can help you check if there is related CW eclipse version that can support your target.
Jun Zhang
%3CLINGO-SUB%20id%3D%22lingo-sub-1011098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%20Windows%2010%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%9C%A8%20Windows%207%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20CW%20v2.10%E3%80%82%E4%BD%86%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20windows%2010%20%E4%B8%AD%E5%AE%89%E8%A3%85%E8%AE%BE%E7%BD%AE%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%8D%B4%E5%8F%91%E7%8E%B0%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E9%94%99%E8%AF%AF%20scrrenshot%20%E5%A6%82%E5%9B%BE%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20782px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F103623i6E08B192800C9FF2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20MacBook%20Air%20M1%EF%BC%88%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%9ASonoma%2014.7.5%20(23H527)%EF%BC%89%E5%92%8C%20Wine%20v10.6%EF%BC%8C%E8%BF%90%E8%A1%8C%20CodeWarrior%202.10%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A0%81%E3%80%82%E5%AE%83%E7%9A%84%E5%B7%A5%E4%BD%9C%E9%80%9F%E5%BA%A6%E8%B6%85%E5%BF%AB%E3%80%82%E5%BD%93%E7%84%B6%EF%BC%8C%E8%B0%83%E8%AF%95%E6%98%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%20PEMicro%20Apple%20%E7%A1%85%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E6%94%AF%E6%8C%81%E7%9A%84%E8%BF%90%E6%B0%94%E4%B8%8D%E5%A5%BD%E3%80%82%E4%BD%86%E5%9C%A8%E8%BF%99%E4%B8%80%E6%AD%A5%EF%BC%8C%E6%88%91%E4%B8%8D%E9%9C%80%E8%A6%81%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1757491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1757491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH4%20id%3D%22toc-hId--538796634%22%20id%3D%22toc-hId-203682449%22%3E1)%20%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20CodeWarrior%20for%20MPC55xx%2F56xx%20v2.10%3C%2FH4%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%20Windows%2010%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20cw%202.10%EF%BC%8C%E8%80%8C%E4%B8%94%E8%B0%83%E8%AF%95%E7%AA%97%E5%8F%A3%E4%B8%8D%E6%96%AD%E5%BC%B9%E5%87%BA%E4%B8%80%E6%9D%A1%E6%9C%AA%E8%A2%AB%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%E6%96%AD%E5%BC%80%2F%E8%BF%9E%E6%8E%A5%E7%9A%84%20USB%20%E7%94%B5%E7%BC%86%E3%80%82%E6%88%91%E7%94%A8%E8%BF%87%E4%BA%86%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Ffaqs%2Ffaq_view.cfm%3FID%3D29%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.pemicro.com%2Ffaqs%2Ffaq_view.cfm%3FID%3D29%3C%2FA%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E7%BD%91%E9%A1%B5%3CSPAN%3E%3C%2FSPAN%3E%E7%9A%84%E6%96%B9%E6%B3%95%E6%97%A0%E6%B3%95%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%E5%9C%A8%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%E4%B8%AD%EF%BC%8C%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%AF%86%E5%88%AB%E5%92%8C%E5%8D%87%E7%BA%A7%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E8%AF%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%AE%BE%E5%A4%87%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%3C%2FSPAN%3E%E6%88%91%E5%B0%B1%E6%98%AF%E6%97%A0%E6%B3%95%E8%B0%83%E8%AF%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3E%E5%9C%A8%20CW%20%E5%AE%89%E8%A3%85%E4%B8%8B%E6%9C%89%20Qorivva%20%E6%A0%B7%E6%9C%AC%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CCW%20MCU%20v11.0%5CMCU%5CCodeWarrior_Examples%5CQorivva_Examples%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%20Stan%20%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%8F%90%E4%BA%A4%E6%8A%A5%E5%91%8A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%96%AF%E5%9D%A6%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E6%96%B9%E6%A1%88%201%20%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%E3%80%82%E4%BD%86%E5%AE%83%E5%AF%B9%E6%88%91%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E4%BA%86%E6%96%B9%E6%A1%88%202%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E4%BB%A3%E7%A0%81%E6%88%98%E5%A3%AB%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%E5%BE%88%E5%A4%9A%E9%94%99%E8%AF%AF%E3%80%82(%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E6%96%87%E4%BB%B6%E8%AF%B4%E6%98%8E%E4%BB%8E%20CW%20v2.1%20%E4%B8%AD%E7%9A%84%E6%97%A7%E9%A1%B9%E7%9B%AE%E8%BF%81%E7%A7%BB%E5%88%B0%20CW%20v11.1%20%E4%B8%AD%E7%9A%84%E6%96%B0%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BD%BF%E7%94%A8%20CW%20v11.1%20%E7%9A%84%20MPC5668G%20%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%8B%8F%E5%85%8B%E9%B2%81%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%8B%8F%E5%85%8B%E9%B2%81%E6%80%9D%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E9%A1%B9%E7%9B%AE%E5%AF%BC%E5%85%A5%E5%99%A8%E4%B8%8D%E6%94%AF%E6%8C%81%E9%80%82%E7%94%A8%E4%BA%8E%20MCU%2010.x%20%E7%9A%84%20CodeWarrior%20%E4%B8%AD%E7%9A%84%20mpc5xxx%20%E9%A1%B9%E7%9B%AE%EF%BC%88%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20DSC%EF%BC%89%3C%2FP%3E%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E5%9F%BA%E6%9C%AC%E4%B8%8A%E6%9C%89%E4%B8%A4%E7%A7%8D%E9%80%89%E6%8B%A9%EF%BC%9A%3C%2FP%3E%3CH4%20id%3D%22toc-hId--743076677%22%20id%3D%22toc-hId--1603772014%22%3E%3C%2FH4%3E%3CH4%20id%3D%22toc-hId-1744436156%22%20id%3D%22toc-hId-883740819%22%3E1)%20%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20CodeWarrior%20for%20MPC55xx%2F56xx%20v2.10%3C%2FH4%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E5%AE%98%E6%96%B9%E4%B8%8D%E6%94%AF%E6%8C%81%20Windows%2010%EF%BC%8C%E4%BD%86%E6%88%91%E5%B7%B2%E8%AF%81%E5%AE%9E%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Windows%2010%2064%20%E4%BD%8D%E7%B3%BB%E7%BB%9F%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88IDE%20%2B%20%E7%89%88%E6%9C%AC%E5%B7%A5%E5%85%B7%20%2B%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E8%AF%95%E8%AF%95%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%BE%93%E5%85%A5%22Program%20Files%22%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B9%8B%E5%A4%96%E7%9A%84%E5%AE%89%E8%A3%85%E8%B7%AF%E5%BE%84%EF%BC%88%E4%BE%8B%E5%A6%82%E4%BD%BF%E7%94%A8%22C%3A%5CNXP%5CCW%20for%20MPC55xx%20and%20MPC56xx%202.10%22)%3C%2FP%3E%3CP%3E*%20%E5%A6%82%E6%9E%9C%E4%B8%8A%E8%BF%B0%E5%BB%BA%E8%AE%AE%E6%97%A0%E6%95%88%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%85%BC%E5%AE%B9%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%E4%B8%BA%20Windows%207%E3%80%82%3C%2FP%3E%3CP%3E*%20%E5%A6%82%E6%9E%9C%E5%AE%89%E8%A3%85%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%AF%B7%E4%B8%8B%E8%BD%BD%E6%9C%80%E6%96%B0%E7%9A%84%20Pemicro%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.pemicro.com%2Ffaqs%2Ffaq_view.cfm%3Fid%3D229%22%20title%3D%22http%3A%2F%2Fwww.pemicro.com%2Ffaqs%2Ffaq_view.cfm%3Fid%3D229%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%EF%BC%88PEmicro%20%7C%20Flash%20%E7%BC%96%E7%A8%8B%E5%92%8C%E5%BC%80%E5%8F%91%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%B7%A5%E5%85%B7%E4%B8%93%E5%AE%B6%3C%2FA%3E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId--63018307%22%20id%3D%22toc-hId--923713644%22%3E2)%20%E5%B0%86%E9%A1%B9%E7%9B%AE%E8%BF%81%E7%A7%BB%E5%88%B0%20CodeWarrior%20for%20MCUs%20v11.0%20%E4%B8%AD%3C%2FH4%3E%3CP%3E%E6%82%A8%E5%BF%85%E9%A1%BB%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%B7%BB%E5%8A%A0%E6%BA%90%E6%96%87%E4%BB%B6%E5%B9%B6%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E5%85%B3%E8%BF%81%E7%A7%BB%E7%89%88%E6%9C%AC%E5%B7%A5%E5%85%B7%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E9%9A%8F%E9%99%84%E6%96%87%E6%A1%A3%20AN4094-CW%20v2.10%20%E5%AF%B9%E6%AF%94%20MCU%20%E7%89%88%20CodeWarrior%20(Eclipse)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%80%89%E6%8B%A9%202%20%E7%9A%84%E5%A5%BD%E5%A4%84%E6%98%AF%EF%BC%8C%E6%82%A8%E5%B0%86%E8%8E%B7%E5%BE%97%E6%9C%80%E6%96%B0%E7%9A%84%E7%BC%96%E8%AF%91%E5%99%A8%E7%89%88%E6%9C%AC%EF%BC%8C%E5%85%B6%E4%B8%AD%E7%9A%84%E8%AE%B8%E5%A4%9A%E9%97%AE%E9%A2%98%E9%83%BD%E5%B7%B2%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E8%BF%81%E7%A7%BB%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%82%A8%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%EF%BC%88%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BA%A4%E6%94%AF%E6%8C%81%E7%A5%A8%E6%8D%AE%E5%88%B0%E7%A7%81%E4%BA%BA%E6%94%AF%E6%8C%81%E9%A2%91%E9%81%93%EF%BC%89%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%22%20target%3D%22_blank%22%3E%E5%A6%82%E4%BD%95%E5%90%91%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E4%B8%AD%E5%BF%83%E6%8F%90%E4%BA%A4%E6%96%B0%E9%97%AE%E9%A2%98%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B7%B2%E5%AE%89%E8%A3%85%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%AF%BC%E5%85%A5%E6%88%91%E4%BB%AC%E7%9A%84%E6%97%A7%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E3%80%82%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%20CW2.1%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E7%9A%84%E9%A1%B9%E7%9B%AE%E7%A7%BB%E6%A4%8D%E5%88%B0%E6%AD%A4%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%BF%E7%94%A8%20CodeWarrior11%20%E5%88%9B%E5%BB%BA%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E6%82%A8%E5%B0%86%E5%9C%A8%E6%AD%A4%E5%A4%84%E7%9C%8B%E5%88%B0%20MPC5668G%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20846px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F99358i7D2DEB5C1838573B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E4%BF%8A%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQorivva%C2%AE%2056xx%20%E5%92%8C%20POWERPC%205668G%20%E6%98%AF%E5%90%A6%E7%9B%B8%E5%90%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%9C%A8%E8%BF%99%E4%B8%AA%E5%B7%A5%E5%85%B7%E4%B8%AD%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E4%BB%8E%20POWERPC%20%E4%B8%AD%E9%80%89%E6%8B%A9%E7%9B%AE%E6%A0%87%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%8B%8F%E5%85%8B%E9%B2%81%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%8B%8F%E5%85%8B%E9%B2%81%E7%89%B9%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%E6%AD%A4%20eclipse%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%9C%A8%20win10%20%E4%B8%8A%E6%94%AF%E6%8C%81%20MPC56xx%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Fcodewarrior-development-tools%2Fcodewarrior-legacy%2Fcodewarrior-for-mcus-eclipse-ide-coldfire-56800-e-dsc-qorivva-56xx-rs08-s08-s12z-11.1%3ACW-MCU10%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Fcodewarrior-development-tools%2Fcodewarrior-legacy%2Fcodewarrior-for-mcus-eclipse-ide-coldfire-56800-e-dsc-qorivva-56xx-rs08-s08-s12z-11.1%3ACW-MCU10%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ECodeWarrior%C2%AE%20for%20Microcontrollers-Eclipse%20IDE%2011.1%20%7C%20NXP%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EJun%20Zhang%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E4%BF%8A%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E5%85%AC%E5%8F%B8%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20Windows%207%20%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%BB%BA%E8%AE%AE%E5%9C%A8%20Windows%2010%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20CW2.1%20%E7%9A%84%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%B3%95%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%8B%8F%E5%85%8B%E9%B2%81%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%8B%8F%E5%85%8B%E9%B2%81%E7%89%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EMPC5668g%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E5%AF%B9%E4%BA%8E%E8%BF%99%E7%A7%8D%E8%8A%AF%E7%89%87%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AA%E6%9C%89%20CW2.1%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E6%9B%B4%E6%96%B0%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%AF%B7%E5%9C%A8%E6%88%91%E4%BB%AC%E6%8E%A8%E8%8D%90%E7%9A%84%20Windows%20%E5%B9%B3%E5%8F%B0%E4%B8%8A%E4%BD%BF%E7%94%A8%20CW2.1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%B8%8D%E4%BE%BF%E4%B9%8B%E5%A4%84%EF%BC%8C%E6%95%AC%E8%AF%B7%E5%8E%9F%E8%B0%85%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EJun%20Zhang%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E4%BF%8A%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MPC5668g%EF%BC%88POWERPC%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%90%91%E6%88%91%E6%8E%A8%E8%8D%90%E9%80%82%E5%90%88%E8%AF%A5%E7%9B%AE%E6%A0%87%E7%9A%84%20CW%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%8B%8F%E5%85%8B%E9%B2%81%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1011099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20is%20supported%20in%20windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1011099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECodeWarrior%C2%AE%20Development%20Studio%20for%20MPC55xx%2FMPC56xx%20(Classic%20IDE)%20v2.10%20%E5%8F%AF%E6%94%AF%E6%8C%81%E4%BB%A5%E4%B8%8B%20Windows%20%E5%B9%B3%E5%8F%B0%E3%80%82%20%3C%2FP%3E%3CP%3EMicrosoft%C2%AE%20Windows%C2%AE%20XP%3CBR%20%2F%3EWindows%20Vista%E2%84%A2%20%EF%BC%8C32%20%E4%BD%8D%E6%88%96%2064%20%E4%BD%8D%E7%89%88%3CBR%20%2F%3EWindows%207%EF%BC%8C32%20%E4%BD%8D%E6%88%96%2064%20%E4%BD%8D%E7%89%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECW2.1%20%E5%9C%A8%20win10%20%E7%89%88%E6%9C%AC%E4%B9%8B%E5%89%8D%E5%8F%91%E5%B8%83%EF%BC%8C%E5%9B%A0%E6%AD%A4%20win10%20%E4%B8%8D%E5%9C%A8%20CW2.1%20%E6%94%AF%E6%8C%81%E6%B8%85%E5%8D%95%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9A%84%E8%8A%AF%E7%89%87%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B8%AE%E4%BD%A0%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E6%9C%89%E7%9B%B8%E5%85%B3%E7%9A%84%20CW%20eclipse%20%E7%89%88%E6%9C%AC%E5%8F%AF%E4%BB%A5%E6%94%AF%E6%8C%81%E4%BD%A0%E7%9A%84%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EJun%20Zhang%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
