How to use the command-Line tools to create library?
3,000 次查看
wwx
Can you give me a example about it which to create a library?Thank you very much.
2,788 次查看
martin_kovar
unfortunately, I do not have example for this case, but all necessary information are described in the document in the attachment. Please look at chapter Command-Line for Power Architecture Processors especially check switch -library.
Martin
2,789 次查看
martin_kovar
Martin
